Here's what Autel has said so far...
My question is- when in fpv mode, why does the gimbal only follow vertical pitch when you move your head up and down? It seems like it could track your head side to side in order to pan too, it obviously has that capability. Was there a technical or financial limitation, other? Or will it be in the next software update now that I've sent this brilliant idea that no one's ever thought of? (Lol, my point being certainly this can't be an original idea of mine).
Thanks in advance,
Thank you for reaching out to us! When you're in FPV mode, you only have control over the pitch for a couple of reasons. The first is that is technically the only controllable movement for the gimbal itself. When the aircraft does it start up, the camera looks left and right, but that is just to make sure that it can reach the necessary thresholds to keep a stable image while the aircraft is yawing or for tracking an object. The second reason is for safety. IF you were to swing your head around quickly because someone got your attention or something along those lines, if the aircraft were to yaw while you did that movement, it could cause a crash. For those two reasons, the gimbal can only pan up and down in FPV mode, as well as in normal flight modes.
Hope this helps!
Regarding your two points, is the gimbals movement only controllable by software design or is there something with the hardware that makes the left/ right motion differ from the up/ down motion?
Also regarding the safety issue, what I had in mind is only the gimbal moving, not the aircraft, so in you example if someone next to you startled you and you turned your head towards them, the aircraft wouldn't move, just the gimbal... the aircraft movements would still be controlled by the remote alone.
Thanks in advance for taking your time to answer my questions,
Waiting for a reply, will post when I have it.
