Thanks Augustine,Latest version of firmware is Version 2.3.3 (Jul 6, 2020)
Latest App for EVO II for Android is Current Version V1.1.5.3
Latest for iOS is Version 1.4.18
Latest Beta for iOS is V1.5.9.
There is no beta for Android yet.
You're confusing the firmware and software/app versions. Your app is up to date with V1.4.18. Or it seems to be from what you said.I’m a little confused, my Autel Evo app on my phone says it’s V1.4.18
Is this the current app? I downloaded 2.3.3. But not sure if this is correct app, can someone please share if V1.4.18 makes sense?
Thank you,
Paul
Thank you Tufargon,You're confusing the firmware and software/app versions. Your app is up to date with V1.4.18. Or it seems to be from what you said.
The 2.3.3 is the version of the firmware you downloaded which is the current version.
Thanks Elder for your help,Hello Waldo, you have not installed 2.3.3!
See here for Module versions of 2.3.3, they are newer then what you have:
EVO II Release Note
EVO II Firmware Release Notes Notes This firmware package V2.3.3 contains the following component updates: COMPONENT VERSION Flight Control 0.0.1.92 Camera 0.2.24.9 Remote Controller 2.0.3.2 RC Panel 3.0.6.0 Image Transmission 1.1.1.27 RC Image Transmission 1.1.1.27 Gimbal 0.1.21.0 Battery...auteldrones.com
Greetings,
Ender
P.S. e.g. Flight Control or Image Transmission...
I see, I’ll need to run Beta I0S to get the module settings updated?Unless your running the Beta iOS app you will not get all of the update settings.
I don’t quite understand what you mean, but currently I’m very happy with how Evo 2 performs even if I don’t have full benefits of updated app.Just a guess on my part but if only half the needed things you need to get the full package and benefits from the update I suspect that might be your problem.
1.4.18 is the APP versione, while 2.3.3 is the firmware version (they are 2 different things)I’m a little confused, my Autel Evo app on my phone says it’s V1.4.18
Thank you,
Paul
Thank you,1.4.18 is the APP versione, while 2.3.3 is the firmware version (they are 2 different things)
. The APP which will be 1.1.6, currently 1.1.15 has not been updated yet, just says not updated in their site, without the 1.1.6 APP
