The more I fly my EVO, the more I see myself getting into a high end UAV at some point. The aircraft is great, but the fact that the controller has set input curves that are not optimal for video, that you can't tweak, is really irritating. This is most true in ludicrous mode where sure, you have speed, but you also have corresponding high speed in yaw, rendering any kind compound camera movement (in most situations) impossible. Standard mode isn't much better. At least Yuneec gives the ability to adjust input curves. How hard can that be?
At the very least, they could have given presets to choose from. Otherwise, yaw is like an on/off switch unless you're in precision mode.
