Evo Smart Battery process
Blooter
How does this auto discharge feature get triggered to the battery itself. In my software it says the standard six day but my batteries are still fully charged after 2 weeks. What tells the battery to do this? If I changed it to 3 days, how does the battery get that command? Does each battery need to be put in the aircraft and started up with the software? I'm not seeing how the battery receives what is in the app. Thanks
The battery has a board which triggers a counter once you charge your battery. I have set mine for 2 days before starting the auto discharge. You set this when you have your drone connected to the app and you have to change it for each individual battery. The auto discharge function discharges the battery bit by bit. It does not discharge it in one go.
Earl
