Blurred images
ryldo
Hello friends
I bought an Evo 2 Pro RTK v3 and the images are all blurred, even the control screen appears blurred. Anyone else had this problem?
I think it's a problem with the camera. I live in Brazil and I don't think I can send it for RMA.
Hello friends
Is the camera in auto focus or manual focus mode? If it is in MF mode then it could be blurry like that. Also, I hate to ask, but did you remove the little sticker on the lens that it ships with?
A câmera está no modo de foco automático ou foco manual? Se estiver no modo MF, pode ficar embaçado assim. Além disso, odeio perguntar, mas você removeu o pequeno adesivo da lente que acompanha?
Hello friend
I removed the sticker yes, no problem asking.
Tested in MF and AF mode.
Hello friend
Definitely something wrong with the camera then, DJI had a bad batch like that a long time ago; the front optical element wasn't polished properly or something like that. Hopefully you can get it replaced.
I believe it could be a problem with the camera.
Thank you friend!
Barry.bain
