D
Deleted member 6303
Guest
When purchasing USB C style cables please be aware of the following - see attached pdf. The connector cable that comes with the unit when measured has a thickness of .2430 with an entry diameter of .2525 (all good) When purchasing higher quality cables the outside diameters are thicker in dimension thus giving a false feeling of being connected to the unit when in fact you are connected to nothing.
Unit is itself has no lag and works perfect. Hope this helps as it almost bit me hard. All the new units are now shipped with all updates and performs flawlessly.
