Testing with EVO RTK and Enterprize with RTK/PPK 6K 1 inch and 640T
jmason702
Just wanted to start a new thread showing our results in the field with these birds, also Emlid RS2. All photogrammetry software is welcome...
Don't want to get too far off topic and somewhat related, what software do you use for PPK conversion? Also, what is the largest area or dataset you have processed with the Enterprise?
I personally don't use PPK, I use RTK, and to date up to 50 acres . with very good accuracy
Reactions: DadCorso80
EVO RTK V1, small project. 130 AGL, 8 MPH, 75/70 overlap. DD could not find any error in the report, again small map. No GCPs
This is a key point, GPS Trust in DD... with the RTK metadata in the photos you get a much greater trust in your mission without the use of GCPs
The next example is non-RTK drone, no GCPs
@Blade Strike is there differences between the EVO RTK and the EVO Enterprize when mapping in RTK? (different RTK Modules perhapse?
No, they are both the same units. Now the enterprise firmware does have some minor fixes on the rtk side but nothing that would improve accuracy.
Aerugo
