Started raining the moment I got in the air, so I made quick work of it! I hope you enjoy.
Drove through Mill City several times.Started raining the moment I got in the air, so I made quick work of it! I hope you enjoy.
While flying on the footbridge about 4 feet up from walkway, there was a lot of magnetic interference and the drone halted and hesitated...I cut that footage out though.I have to say that took some guts to fly under the bridges
Magnetic interference is a real possibility under steal structures. I have seen personally one of my UAV's just take off in a different direction because of flying near a bridge. I use caution anytime I fly near them.
Thank you.Drove through Mill City several times.
I always see the bridges from the highway.
You did an excellent job!
Thank you. The Evo halted and hesitated when flying on the bridge about 5 feet above the deck surface. It was basically inside a giant metal cage at that point and sort of hesitated or slowed and almost stopped a couple times. But i edited that footage out. Going under bridges was no problem.Nice flying! I would never fly down or under a metal bridge in an XSP. Like others, I’ve had it start flying erratically in that kinda situation.... Maybe the Evo is less susceptible to magnetic interference??
Hmmm. I am not 100% sure of the cause of the hesitancy. It has never done it before but I have never flown it within so much steel. I have flown it between trees in similar fashion and never had a problem. I did have obstacle avoidance on but there was no indication that was the cause (there was nothing in front of it and screen did not display the red colored 'radar' bar on screen. But I did get a couple of magnetic interference warnings while I was flying slowly in a straight line within the cage of the smaller bridge, so I assumed that was it due to all the steel, but who knows.I would question if the magnetic interference was causing your problems with it hesitating/slowing or almost stopping. I would think this to be more the FOA sensors acting up. Or do you fly with FOA off?
I have not heard about many "fly aways" with the Evo - but would suspect something like this, before I'd think the drone just wouldn't move at all -- because of the interference.
