What brands of 'memory' cards are recommended for the Evo ll pro
I understand up to 256 gb can be used .... BUT what size is recommended ??
As you can see by my questions I know nuthin about memory cards ( but there was a day you knew nuthin too - so be kind )
I saw Toshiba won a test as to fast writing and they were <$12
They were (copied from above post) UHS-3 rated
That is a 3 inside big 'U' I think....
Toshiba 256GB M203 UHS-1 C10 MicroSDXC Card Speed Class: Class 10, UHS Speed Class 1 Read Speed: Up to 100 MB/s Specialised for Full HD video recording, for Android |
The short answer to why use a 128 vs 256 is it's better to swap out cards rather than rely on one card to not fail or heaven forbid; the drone is lost. at least you will have the previous flight(s) recorded.General question....
Why only 128 GB when Evo ll pro is capable of using 256 GB ????
What is it I don't know or understand +???
I ask because I read a 'test report' about the actual speed of writing of various cards and TOSHIBA was the undisputed fastest card to be written to.
Now I will have to find the test report to back up the information
here is a 'biased' report from Toshiba .... Amazon.com: Toshiba USB3.0 Flash Drive 128GB 128G USB 3.0 Flash Disk TransMemory U365 Read 150MB/s Slide (THN-U365K1280A4): Computers & Accessories
Sorry about the long link address
Found this while looking ... Speed is stated as Class 10 - BUT I was told to make sure a 3 was inside the 'U' sign - it's only a 1 here
