Good luck!I will try that after I finish charging the RC. Thanks again for your help, keeping fingers crossed.
Follow Blade Stike's adviceI have found conflicting advice regarding what to actually save to the SD card. One is to save just the zip file. Two is to save the unzipped/unpacked files directly to the SD card. ?????
That's awesome! Congrats! You did it!Many thanks, Lifeisfun. Followed the guideline, flashing the aircraft from the SD card completed in 10 minutes. I waited about 15 minutes to make certain that it had completed. Shut down the aircraft and RC. Removed the SD card and formatted it on my laptop. Reinstalled the SD card. Connected my iPad to the RC, booted up the RC and aircraft. Immediately knew that something was different, when Autel Sky started up, the color of the start button changed. I pressed start and the window opened and then there was a pop-up notifying that there was an update available. I started the update and it completed without a hitch. Shut down and rebooted everything and calibrated the IMU. Plan on performing a compass calibration in the morning and getting back to flying this fantastic drone.
Did you read posts and links I posted above?how to update via sd, I downloaded the firmware, do I need to save it on sd in zip format? Can you elaborate on how the update works?
Please be careful of loading from sd card. There is no app progress so you must watch the rear led.yes, I just did as you wrote above, the drone was updated, blinking green quickly, and the remote too. rebooted the drone and the remote control, connected the phone, but after turning it on, the drone blinks red. I will try again. Firmware uploaded 1.3.26
Did you try binding the drone to the controller? Did you try reversing the cable?the drone was updated, did as it is written above, everything turned out, super!! now I start the drone, controller and mobile, the drone slowly blinks the green indicator. the application does not update, there is no connection
Well, I would probably try to flash the update again.yes, I have tried reversing the cable, reinstalling the app, with no result. I tried to connect the drone and the controller manually, also without result. there is no update message when launching the application.
ok, I'll try again. Thank youWell, I would probably try to flash the update again.
