Help Needed: Connection Issues and Quick-Shot/Track Problems with Autel Evo Nano+
Paul@foxes
Hello,
I recently bought a used but like-new Autel Evo Nano+. This is my first drone, and I have no prior experience with drones. I bought it for simple photography during vacations at quiet beaches and for capturing nature scenes.
Now I have two problems/questions and hope for your support:
1. Connection Issues:
Since the first flight, I have had constant connection losses between the controller and the drone. This happens in completely open fields without any obstacles, even after just a few meters of distance. First, the controller shows a full connection to the drone, but suddenly the connection drops, and the drone starts RTH (Return to Home). After a short moment, the connection is restored with full strength, and I can cancel the RTH and continue flying. This happens every 20-30 seconds.
After checking different settings, I discovered that switching my iPhone 15 Pro (which I use as the display) to flight mode makes the connection stable. However, I feel like the RTH accuracy has suffered since then, and I would also like to stay reachable when flying the drone.
Do you have any explanations or workarounds for me?
2. Quick-Shot and Tracking Features:
I would like to use the Quick-Shot and Track features, but I am having trouble activating the “Plus” symbol on the display. So far, I haven’t found a tutorial explaining how this works exactly. The “Plus” symbol only appears briefly or is very difficult to click. Is there a trick to make it easier to activate?
Thank you very much, and I wish everyone a nice evening!
Greetings from beautiful Lower Bavaria.
Start by using a different cable from controller to phone
Reactions: ADOC
also, when in follow/quickshot mode you can doubletap and drag an area of interest, instead of clicking on the + button that tends to appear when it recognises a person.
I tested it with an Apple-USB-C Kabel and order different short USB-C-Datacabel. Allways the same, without flightmode, i have frequently connection losses.
@Martinusisko: Thanks for answering. I will test the doubletap!
Pkelley
