- Joined
- Jul 6, 2020
- Messages
- 6
- Reaction score
- 1
- Age
- 73
I dont think so, I would try all batteries however, shut down, restart and verify if the update pops up again. In my case the updates keep popping up no matter how times I update. Good Luck and I would call Autel for confirmation.Do I need to run the update on all batteries?
never mind, I mis-read that; you didn't say you called Autel.... lolI dont think so, I would try all batteries however, shut down, restart and verify if the update pops up again. In my case the updates keep popping up no matter how times I update. Good Luck and I would call Autel for confirmation.
Charging my batteries now to do the update. I will advise when do the firmware update.Hmm... i did the update to 2.5.18 and it went fine, my packet versions are different though... the camera and vision packet are not V0.2.30.30 as it says in the patchnotes. Someone else?
So?Charging my batteries now to do the update. I will advise when do the firmware update.
Sorry I got tied up with other things. The firmware update had no issues. loaded up and fired up my drone without any issues.
The question was what version your packets show after the update. You can check it on the app.Sorry I got tied up with other things. The firmware update had no issues. loaded up and fired up my drone without any issues.
I also had the same experience when it came to the packs. But no issues.
Ah, i see, that's what i wanted to know. I have no doubt the update will work, it always did. But Autel also has a history in screwing up versions - so i wanted to know if my drone just ignored a few packages or they just screwed up - seems to be the latter ;-)I also had the same experience when it came to the packs. But no issues.
Flight control v0.0.4.7The question was what version your packets show after the update. You can check it on the app.
Sorry for the confusion.Ah, i see, that's what i wanted to know. I have no doubt the update will work, it always did. But Autel also has a history in screwing up versions - so i wanted to know if my drone just ignored a few packages or they just screwed up - seems to be the latter ;-)
