- Joined
- Oct 5, 2018
- Messages
- 16
- Reaction score
- 8
- Age
- 61
I've attached 3 LUTs that I created today for the EVO. These are used for color adjustments for recordings made using the "LOG" color option. I was unable to find any EVO LUTS online so I took a stab at creating these. I hope someone can find them useful.
These are standard LUT files. I tried them in Final Cut Pro X and they worked fine. To use them in Final Cut Pro X, select the EVO clip and open the inspector. At the bottom of the inspector window, select "General" or "Extended" from the little menu button. Look through the inspector to find the entry for "Camera LUT." Select the LUT type to right of "Camera LUT" and sub-menu to "Add Custom Camera LUT..." Once you have added the LUT it should be available in the menu for use the next time.
I didn't try these LUTs on any option besides LOG, as they LUTs probably aren't needed for non LOG recordings. I'm very open to complaints or recommendations to make these better.
