evo 2 v3 fly away
prop
big problem today . i took off in my usual location and the drone flew directly into the building were i was at. i have been taking off and landing in this same spot for months with no problems until today.it took a pretty hard hit and fall . i changed the blades but it says gnss signal is weak and geo awareness may be disabled. any ideas why it could have flown off? thanks
Have you taken your drone to fly at a different location roughly 20 miles away, without recalibrating the compass? Maybe there was/is extra interference in the area.
I had a similar issue when I first bought my V3, took off from my deck and it flew straight into the house. I was luck only the props got damaged. Then there was an Autel guy, Ken Booth I think, I forget his name who read my logs and said to return the drone due to emu and compass malfunction.
I have the same issue, l won’t launch it until l do not get the error. But if Autel doesn’t have a solution it will be returned.
yuval
