I toyed with this once before and wasn't completely satisfied with the results. This time I used a piece of G10 so the mount would be stiff and I shaped it to the controller so I can still get to the back button if I want. This works extremely well I don't have to hold the weight and the try-pod is light so it is easy to move to shoot at a different angle. The Velcro is 1 inch wide and is rated at ten pounds it holds good you have to pry it loose when your done flying. Some of us elderly gentlemen need a little help.
