internal storage evo 2 pro v2
J.go
Hello friends, the internal storage of the drone does not show the saved images when connecting it, those folders appear, has anyone else experienced it?
I use macOS so it a looks a bit different, however the internal storage remains empty if you have selected the SD Card as your file destination.
I normally remove the SD card and stick those in the back of my iMac for 10 times faster transfers so I hardly get to see the drone's internal storage. But when I connect the drone to the iMac via the UCB-C port on the aircraft, the internal also appears on my computer. Shows up empty as explained, because I always use the SD card.
Check your settings while the explorer app is connected to your drone.
There are two save modes, one is called Flash Card and the other is SD Card. Where Flash is referring to the internal storage.
Make a photo on both and thereafter find out where these files appear on your computer.
STEP 1, go to "Camera Settings", being the last icon in the bottom row.
STEP 2, scroll to "Save Location"
xander0791
