Hybrid waypoint ...?
jkproduction
I have to shoot vertically down at an altitude of 30m, 40m, and 50m at 30,000 coordinates.
Is there a way to manually allow automatic filming of each altitude of 30m, 40m, and 50m after the flight?
Or the other way around?
Setup a map mission (rectangle or polygon) with the area to capture, set camera/gimbal to 90, set your overlap (side and forward) as needed, adjust speed, and 2D or 3D (crisscross), then fly mission at 30m. Then repeat mission for 40m and then 50m, when done process the three missions with whatever software you need. If the area is very large, you might have to do multiple missions at each alt, and multiple batteries.
Chen
