Flight Records Messed Up
danfo
Last night I installed the new firmware 1.3.3.25 had a few questions about screen resolution afterward, so called Autel. The tech had me uninstall and reinstall the Explorer app. Later I checked my settings and Flight Records. Since last evening my flight records map shows a Giant Google across the screen.( see picture) Everything was fine before last night so I don't know if it was firmware or reinstalling the app? Does any one else have this issue? My Flight Records are worthless now. Any ideas?Flight Records4.jpg
Wow i've never seen that. That's really strange. I doubt we'll be able to help you here with that. That looks more like a google problem but I'd get back to Autel support for sure.
I came up with the fix for my problem! Everything is normal now all flight records are now on my Note 9 and I can now sync my flights. I would be surprised if eventually we don't see others with the same problem. In case others have this problem, the issue is screen resolution. If you go into settings-display-Screen Resolution, there is three possible settings on the Note 9, HD+ 1480x720, and FHD+2220x1080 and also WQDD+2960X1440. The screen resolution cannot be HD+1480x720, either of the other two settings will work.
Good info, thanks for sharing it.
Bailey54
