I was entertaining a modified X4S (precise trigger with M2) to use with Reach M2 onboard an I2 or M210... or direct M2 interface with a A7Riii under a M600Pro... maybe a A7Riii and the newer LIDAR a dual setup under M600Pro with the Reach M2.
Full Version trial - 30 day per email address.
That would be RealityCapture by CaptureReality.Thanks, I am pretty sure they moved on from PIX4D, last I herd. I hear Context Capture is the one to be checking out.... not Agisoft
I’ve not directly used DD, based on several examples and the flight paths applied would be my limited comparison. I remain impressed of the included features & reports within DD. The DD package provides high quality results, the limitation to me is cost compared to other options. The 2D ortho I think are equal and the 3D I feel CaptureReality has the greatest potential. But I remain hesitant which to purchase; both MS and RC have their strengths.Very Nice, How do you think all 3 software compare to DD?
I'd strongly agree, the more I experiment, the more RC is tops! In many other models I've seen , outside of aerial... RC is easily producing results above the rest. If you tweak the setting, it gets even better results.I just ran the same set of images in Drone Deploy, Pix4D Cloud, Pix4D Desktop and Capturing Reality and then made a 3D model. I didn't make any changes or try to adjust anything. Just upload and process.
Pix4D Cloud made useless garbage.
Pix4D Desktop made an ok model, but nothing that I would give to a client.
Drone Deploy made a really good model.
Capturing Reality made a very good model.
My pure opinion, question and guess is, Is Drone Deploy using Capturing Reality for their processing now? The models look very, very similar.
I used Capturing Reality to reprocess images from a model I did months ago, and it came out beautiful.
My biggest question is, how accurate is Capturing Reality? Pix4D has so much info as far as tests for accuracy. When I do go the route of adding GCP's and checkpoints and work with a surveyor, is CR going to stand up to Pix4D? Pix4D may suck at generating the mesh, but when done right its dense point clouds have proven through many tests to be very accurate.
@jaja6009 in looking a bit more at RC. I actually feel the accuracy "can" be higher in RC than Pix4D, but the biggest point of variance isn't the software, but the drone & camera.I just ran the same set of images in Drone Deploy, Pix4D Cloud, Pix4D Desktop and Capturing Reality and then made a 3D model. I didn't make any changes or try to adjust anything. Just upload and process.
Welcome to forum... might also want to check out Commercial Drone Pilots... several map/survey/modeling discussions too.This is a very interesting post. I just left a survey company in Tampa and moved to Miami with my girlfriend. I have a M2P and an E2P and have done aerial surveys before. I also just got my Part 107. This post makes me want to approach some survey companies and offer my services, either as a contractor, or an employee. I do not have a Rover and Base though, so I wouldn't be able to get my errors down. (Curious why you used NTRIP with a base and rover if you could have just used a Rover and DOT network with NTRIP)
I just have a few questions.
Are you doing this for a survey company or providing this service as a contractor for companies?
Is there any demand for just the Ortho without precision from GPS instruments?
Where are you based out of?
I've been looking at other types of services that involve drone imaging and have consulted a few websites, looks like inspection jobs would benefit from these orthos as well, have you done that or mostly just plats?
Thanks for the post man, summoned some ideas.
OH and if anyone knows of any great survey companies in Miami/Fort Laudy, hit me up!
