Evo 2 Camera Replacement Video
Nice to see the procedure, I have been waiting to see the type of connector implemented.
I was expecting a compression ribbon socket, surprised to see a micro snap socket.
Same basic micro connector that M2P/Z uses, but they've added a nice retaining plate over the top in place of using the cover as a tension retainer.
But it's interesting they chose this design since this type of connector has a limited number of rated disconnects for successful & reliable connection... retained or not retained. The retainer plate is nice to insure it remains on, but it doesn't improve connectivity reliability of the micro connector over several disconnects, that is within the tension of the prongs inside the micro socket.
I'd say it's still a great feature to swap gimbles, but I don't think it's intended for frequent swaps, although MTBF is probably higher than most would swap anyway. I infrequently swap the M2P/Z for same reasons.
Chen
