Battery with overcooled error message
H2l
I have just received à new battery, it is at 50% charge but once I plug it to the charger I have the second led flashing assuming à temperarure issue and once pluged in thé aircraft the system shows an error.
Any idea How to solve this ?
Thks
Hh
I would first charge it and update it with the newest firmware and see if that helps.
Is the message a recommendation or it wont let you arm the motors? I have never heard or seen this error before, so I am keen on learning about it.
I can't charge the battery do I didn't fly the drone in this condition. The sensor within the battery tells me that the temperature is - 52°C.
That s cold indeed. So something isn't working.
I suggest you get your battery exchanged. Clearly the sensor of that battery is busted or stuck.
I hoped to find a solution as I am way traveling, with just one other battery. But it is probably the best solution indeed.
May replace temperature sensor can fix the problem, Have your battery ever dropped?
Thks
Hh
How it has been fixed?
just got this exact error.
-53.4 c . Summer in Australia so definately not environmental temperature
Battery has 25 discharges and about 13 months old
Has anyone had success in fixing this? Im currently attempting to run it right down and recharge, but not liking my chances here
Ive had my Autel Evo 2 for three months and im in Jamaica with the same problem. Battery Overcooled
Autel wont exchange the battery i tried that on my three month old drone.
Aerugo
