Thor mount and Alientech
AnchorageAk
Can someone posted a picture of this setup? I am having a hard time trying to put it together.
So I have the 4Hawks which is pretty much the same style setup. Here is a few pictures.
Reactions: PTBperegrine
Thanks. Didn't know I needed the adapter. No wonder it wouldn't work. Wished I had know that before. Had just ordered the CS adapter, and now another $26 shipping. But, still a cheap education.
here ya go. I used 2 extensions to clear the mount and a adjustable flash bracket for a little support but not needed.
I use the same duo antenna for my Evo2 And Mavic‘s.
I got about 20% further replacing my Lyftor mount and those extensions for the Alientech, by using the Skyfire mount which doesn't require those extenders. Ended up with lighter setup and more range go figure. I run into what I call a wifi wall in my area. The cable provider as a service to its customers, has Wifi Towers all over to cover the public spaces. And its both 2.4 and 5ghz. And needless to say those towers put out more power then a normal wifi router.
Where did you buy the extensions from, do you have a link please?
Forgot to mention, if you have the Lyftor, be sure to get the $35 extensions
Beforre I order them can you confirm it is this one please
Yea, that looks correct. If you want just order from Covertdrones as he has all of it. He can do the install as well. They have a new Duo II that is 2.4 and 5.8. I know Evo doesn't use 5.8 but the 2.4 is a bit more db then the regular 2.4 alentech for a bit more money. I'd talk to Lucas at covertdrones he'd have the correct advice on it all.
MFJ
