Smart Controller SE V2 Firmware update
Hi Raik,
Habe sie heute zurück geschickt.
Mit der Bitte um Austausch und in Rücksprache mit Autel
Bin mal gespannt, was passiert.
Gruß und schönes Wochenende dir!
Max
Hi Raik,
Max
Servus Max,
ja das würde ich in deinem Fall wahrscheinlich auch tun, da deine Drohne ja überhaupt nicht mehr reagiert. Bin echt gespannt wie das abläuft.
Ich warte derzeit auf die Lösung vom Support. Alle Daten haben sie bereits inklusive Logdateien. Hab das Gefühl, dass sich jetzt übers Wochenende nichts tut.
Ergebnisse teile ich dir auf jeden Fall mit.
Dir auch schönes Wochenende
Raik
hey guys any update? im having the same issue.
hi, for the most people the following method does solve the issue.
Unfortunately, it does not solve my Problem. I am still in contact with the the support team
It might help others if you spoke in English in an English forum.
My last final post including the solution was in english. The link to a german site is due to the fact that it is the only complete solution i ve found including files and description. But, in the age of artificial intelligence this might not be a problem to translate. If someone still has a problem to update the remote controller, i also have a solution to force the controller to an update
For those who want to read it in English.
Offline Update Guide for the Evo Max and Alpha Series​
  • Author photo: DP-DYNAMIC
    DP-DYNAMIC
  • May 21
  • 2 min reading time
Rated 0 out of 5 stars. No ratings yet
Do you have an Evo Max or Alpha drone and want to install a new update?
No problem, we'll explain how it works.
ATTENTION : Disable Stealth Mode! (Otherwise, you won't see the status LED during the update.)
Document the firmware version of the drone and RC in advance under "About".
Check build/version under Android "Settings" - "About phone" here it should say Neutral or Autel for normal users.
Info: BOS customers have a special firmware from us and receive the update via SharePoint (QR code on the RC)
Firmware update Evo Max for download:
Autel RC Version:
https://drive.google.com/drive/folders/11SIfZAvB0mfCUYjas_gExAXUvkqXxf1B
Neutral RC Version:
https://drive.google.com/drive/folders/11S1bOBuM1Gpcld6_28rSK_C_GlsMzGoW
DP-BOS Version:
Only upon request to authorities.
Drone Autel/Neutral:
https://drive.google.com/file/d/1q0TkLnvUfOjyhRMRzBRzDZy9NNr6dgg1/view?usp=drivesdk
Step by step instructions:
Remote control (RC):
1. Download update file (RC79...uav)
2. Place ONLY this file (RC79...uav) in the root directory of the USB stick
3. Turn on the remote control, start the UAV app if necessary and wait one minute and then connect the USB stick.
4. Update pop-up appears via the app, please confirm and update the remote control.
4A. The green status LED of the RC FLASHES alternately up/down, a message appears and the flashing stops when the update is successful.
5. Restart the remote control when prompted (long press on the power button)
6. Updates successful, restart RC and update drone.
If error message -100 appears on the smart controller, please do not press anything and let the RC run for 70 minutes until the RC restarts... the LEDs 1&4 should flash.
Drone (AC):
1. Download the update file.
2. Place these unzipped files (ModelX / ModelH…uav) in the root directory of the MicroSD card. (No other files should be in the root directory.)
3. Turn on the drone (remove the gimbal cover first) and wait 1 minute (boot time) before inserting the MicroSD.
4. The update takes about 30 minutes, please DO NOT reboot beforehand!
4. The drone's status/motor boom LEDs will FLASH green during the update, and all LEDs will turn solid GREEN after 30 minutes to indicate the update is complete.
5. The battery status LED FLASHES in the middle, if the update is successful, the LEDs cycle from left to right.
6. Each battery should be inserted briefly, the UAV app will launch, and a "Quick Module" update will be installed. The battery update receives the update from the drone; no internet connection or update stick is required. The update takes about 1 minute, and the drone must be restarted afterward.
7. Remove MicroSD and restart the drone (the .uav file should be deleted after the update is successful, if not, remove the update file)
8. Now the drone and RC should be on the same firmware version and should automatically find the connection/pairing again.
Offline maps for import via USB stick:
Please write to us, we have nationwide offline maps in satellite and vector view
Failed?!
Error code 10011, 10003, 10016 = wrong firmware for the update - not compatible... use another FW or contact [email protected] .
Hello.
Evo Lite 640T. I also received and preformed the ota update, aircraft to V1.0.3.71 and remote control to V1.0.3.65. Both updated without problems but it seems to have broken the video transmission between ac and rc. Everything else works normally but picture gets blurry and freezes when the distance between rc and ac gets above 400 meters, even though the signal strenght is full. It also once popped up a message that video transmission software mismatch.
On previus software I had non of these problems, it was good picture quality over 1000m. Has anyone else got this problem, or even better have a solution for it?
Update
Hi Raik,
Habe ein Austauschgerät erhalten mit neuer Firmware.
Jetzt funktioniert alles einwandfrei.
Auch ein weiteres Firmwareupdate ging ohne Probleme.
Liebe Grüße
Max
Update
Hi Raik,
Liebe Grüße
Max
Hallo Max,
habe deine message gar nicht bemerkt und keine email bekommen.
Wollte dir auch gerade schreiben, ich habe mittlerweile 5 Wochen gewartet. Heute haben sie mir den Kaufpreis erstattet und gleichzeitig eine Ermäßigung bei einem Neukauf von 6% angeboten. Du hast sie auch von Autelpilot, richtig?
Liebe Grüße
Raik
Hallo Max,
Liebe Grüße
Thorsten
Hi Thorsten, (ich glaube ich habe deinen Namen verwechselt)
Danke für deine Nachricht! Bei mir ging es auch hin und her mit dem Kundenservice in Shanghai. Dann haben sie mir eine neue Drohne geschickt und die funktioniert jetzt einwandfrei. Kurz darauf kam ein Firmwareupdate und ich habe schon gezittert... Ging aber dieses Mal einwandfrei durch..bin jetzt fast jeden Tag damit geflogen und zufrieden mit der Drohne. Auch wenn mir das alles viele Nerven gekostet hat..
Lg
Max
Lg
Max
Hi Max,
Ja Raik ist mein Zweitname ;) hab nicht aufgepasst.
Das freut mich dass das bei dir alles geklappt hat. Ich hoffe bei mir jetzt auch.
Das ging ewig hin und her, sie konnten oder wollten kein verbindliches Lieferdatum nennen und die Wochen verstrichen nur so.
Dann Anfang dieser Woche habe ich ein Paypal Konflikt eröffnet, ab da ging es ratzfatz. Zuerst baten sie mich diesen zurück zu nehmen weil das warehouse ansonsten nicht liefern könne. Ich blieb aber hart, da ich in dem Fall den Käuferschutz verlieren würde.
Kurzum sie haben das Geld erstattet anstatt Ersatz zu liefern und mir zum Neukauf nochmals 6% Rabatt angeboten als Wiedegutmachung. Der Preis ist somit halt schon sehr niedrig. Ich hoffe das Ding kommt jetzt bald, es sei auf Lager in Deutschland.
Wenn es da ist und funktioniert, halleluja.
LG
Raik
Hallo Thorsten,
Interessant, dann haben es die Ganoven genauso probiert wie bei mir.😁.. Erst als ich bei Klarna einen Fall eröffnet hatte, kam wirklich Bewegung in die Sache. Und einen Rabatt haben sie mir angeboten, wenn ich den Fall vorzeitig schließe, was ich natürlich nicht getan habe. Am Ende habe ich noch Einfuhrabgaben vorgestreckt, die sie mir aber umgehend rückerstattet haben.
Hallo Thorsten,
Hi Max,
hab sie heute endlich bekommen.
Es sind die gleichen firmware Stände wie damals.
Es heißt ich soll updaten. Ich hab Angst.
Wie lief das bei dir?
Welche Firmware ist jetzt aktuell bei dir drauf? Und wie lief es ab? Wie lange hat der Update Prozess gedauert?
Hallo Thorsten,
Ich bin gerade unterwegs und kann erst später nachkucken.
Laut Autel wurde das fehlerhafte Update vom Netz genommen. Ich würde es wagen. Bei mir musste auch sofort geupdated werden.. Ging ohne Probleme . Wenn wieder was schief geht, dann besser jetzt gleich 😊bin heute morgen geflogen und die Drohne fliegt klasse..
Hallo Thorsten,
Beim zweiten Einschalten war der Stealth Mode und das Aux Light weg. Kriegs nicht mehr rein. War bei der damaligen auch so.
Dann, weder die Piloten ID noch die UAS Betreiber ID nimmt er.
Hast mal lust zu telefonieren?
Alvance
