OK, I've got my replacement EVO and......
So you're saying I cannot have the older version installed on my Android phone to help fly the missions and I ca use the IOS version on my ipad mini if I want to fly the newer version?
No, the video is to show you how to use the older version on your android. Which will 100% work. As far as I can tell for IOS is that you could be stuck with the version you have until another update.
Clearly to summarize:
IOS and ANDROID are two different systems.
On ANDROID, you can install and reinstall the version you want and revert to an old version.
Explorer 1.0.1.45 --> Explorer 1.3.0 --> explorer 1.0.1.45 = YES
On IOS, it's almost impossible to reinstall an older, later version.
Explorer 1.0.1.45 --> Explorer 1.3.0 --> explorer 1.0.1.45 = NO
This is the big drawback of IOS, you do not install what you want.
Reactions: Tufargon
You can have the older version in your Android phone and the newer version in your iPad Mini. Your Evo will work fine in both. I used to have an iPhone for testing, but my sister stole it.
Reactions: Tufargon
So you're saying I cannot have the older version installed on my Android phone to help fly the missions and I can use the IOS version on my ipad mini if I want to fly the newer version?
OK I installed the 1.0.1.45 version and it works better but there's lots of room for improvement. It is very hard to produce great videos with a flawed app as there are no POI's and no smooth curves when passing a waypoint. LOL it still sucks and I am certain that Autel could have provided a better alternative for waypoints.
POI and curves, reserved for version 2 of the Evo.
If the next car you have ends up with 15 new improvements, the manufacturer will not put them on your old car ......
Sparky311
