New Titan "Switch" Antenna on the way
Great idea, post pic with a phone or tablet attached, Thanks
Is that the farthest the phone & phone holder will tilt backward? Is it more uncomfortable to fly as a result? How's phone visibility, weight distribution and handling?
Yep that's it. It does interfere a little bit with the tilt but it's not that bad. Front of the transmitter is front heavy but again nothing that bad.
Did this increase the range? asking because I need to deal with trees.
Of course it increased the range! In one direction I was only getting about 1 1/4 miles out before I lost signal and after installing the Switch antenna in the same direction I am now getting almost 4 miles!
If I use the built in monitor only (without a phone) can I see the GPS map. For long distance I need the map.
The antenna is just too darn heavy to be putting on the front of that small controller. Main reason I sold mine.
adunsky
