Sign up
Multi-battery charger from Autel at CES
jcmarceau
Yes i saw that on you tube so i was right...it’s on it’s way ;)
Bulldoggboyz
Okay lovely! Sooo...What do we know about said multi-charger? Will it charge the batteries simultaneously or sequentially?
Typhoon Charlie
Montana
Not the aftermarket mavic charger I have. And why can't they be better than DJI? That's the problem with my m600 and 210 rtk. Take for ever to get a et of batteries charged. It's not rocket science.
jcmarceau
Sequentially, starting with the one closest to 100%
With the video i saw on you tube of original dobo on the multicharger its seems its charging all the batteries at the same time and not sequentially because you see two batteries that the lights are blinking at the same time so you might be wrong my friend when it is sequentially there is blinking lights on only one battery at a time ....anyhow with all the dji multicharger i had.
Original Dobo is at CES and he respond to me about this and he said they charge all at the same-time balance.
WayneH
Orange County, CA
That is how other DJI does it with their Mavic charger.
Just to be clear - DJI doesn't make a multi-charger. Those that are available are all aftermarket.
(At least that is my direct experience to this point. Sold all my Digi stuff several months ago and don't check into that blog anymore, so I might be behind the times.)
Agustine
Moderator
Staff member
Northern Ontario
So what is the price on this amazing wonderful futuristic device that does everything but the dishes :)
Anybody know?
Bulldoggboyz
Anybody know?
Well...If the newly released car charger is $80.00 I would assume the multi-charger will be at least $100.00 if not more.
forester801
Ontario
If you look at the youtube videos of autel's booth at ces, you can see that it charges all batteries at the same time..
WayneH
Orange County, CA
Reactions: Cyberjunkie
Cyberjunkie
Not exactly. As outlined in several posts, a strip of plastic must be removed, a simple task. Takes all of 5 minutes to do all three.
Thinking this could be a better $ choice than what I see in CES
Mountain View Productions
