- Joined
- May 9, 2021
- Messages
- 293
- Reaction score
- 153
- Age
- 68
- Location
- Kingwood, TX
- Website
- www.raptoraerialservices.com
I apologize if this topic has been covered elsewhere. I have found some info but not exactly what I need.
My primary work is aerial mapping. I mostly fly Polygon Missions. I am constantly having problems with the camera settings during a Mission. Typically, I will go up prior to the survey and fly using Camera mode to ensure I know what camera settings will work best. I also set the Manual Focus at about 100-150' AGL. I can get everything to generally work ok using the Camera option. No so, when flying a Mission. The only 2 settings I can generally change is AUTO/MANUAL ISO MODE and AF/MF. The other settings I have not been able to figure out how to change. My goal, is the duplicate camera settings I use in the CAMERA mode for MISSIONS. There may be a simple solution that I am not doing. Any thoughts/suggestions?
