Less than 11mph
Tom Z
The options in the menu are nice to controll the speed between 11mph to 33mph.
Anyone know if Autel is adding a feature to slow the aircraft down even more, something in the area of 2-4 mph. For me the 11mph is still too fast for some video work and having the ability to slow it down even more would be great.
Or maybe there is a way to do this already?
Joystick inputs are proportional. I simply push the stick forward slightly to move slowly, push it more for more speed, and so on. . .
Cheers,
Dan K.
Reactions: Mr $panky
Makes sense, but I need a smooth constant speed , and can't get it with pushing the joystick a little bit a time. Hard to keep it exactly at the same position.
Just like the yaw is a problem can't smoothly do it.
You are life saver, I completely forgot that one can fly waypoint missions and control the speed.
Will have to play with it a little when it warms up a little bit outside..
thanks,
I assume if you fly a waypoint mission you can use the right stick to slow the aircraft down below 11 MPH. Might be worth a shot for some applications!
bogieboy
