How to make orbiting in a planned mission
noidsr
Hey guys, question I have is how to plan an orbiting around some objects in a mission? It seems all straight lines. I hope I am not missing anything here. Thanks!
I've only been able to do a 180 or less with subtle changes that neither slow down or stop the drone. it comes out ok but I don't believe you can invoke the "orbit"
Assume you have tried setting up a POI in your missions, then have each wpt use that POI? Then depending on how you have your wpts arranged, you can fly around the POI.
Granted, its not a smooth orbit via mission which is needed, however its a work around.
Another workaround is note your alt, GPS lat, lon, gimbal angle, then using a waypoint to position (then cancel mission), or position by hand, start an orbit mission.
Yeah its a lot of workaround for what should available or a good feature, however its a workaround while waiting.
Great ideas, especially the last one. Thanks for sharing it.
Reactions: gschulzuio
dbuckner0138
