Help with camera mount question
Could someone please take a look at your camera mount. I crashed my pumpkin on Sunday and broke two pins. I replaced him with the two clear plastic pins that came with the Drone. They are both longer then the existing to pins that did not break. They are on diagonally opposite corners but they look funny. Are your pins all the same length or are there two long and two Short?
You should have two pins holding the gimble. They are both the same size.
Thanks guys for the help. Problem resolved. The crash made the rubber grommets pull from the camera mounting frame so I stuck another two pins into these grommets also. By simply inserting the grommets back into the frame all looks well again except now I have pins in all 4 grommets. BTW they are all the same length. Now need to clip 2 of them and will be back to original. Was confused for awhile but now makes sense.
coastaldrone
