Gimbal Sounds
Edwinpilot
Hi guys, today i tried to fly my autel, I get a sound when i turn down the gimbal, like a pimmmmmmmmmm and the camara star to vibrate
how can i do to solve it
How cold was it outside? If below normal temps the little servo motors are working over time. If you live in a warm climate then call Autel to get their take on it.
Reactions: Edwinpilot
Hi on Lima, Peru, on this moment the temperature is like 27 Celsius.
I will write them
this the video of the problem
what do u think would be the problem?
I really do not know. Sounds like something is binding to make the motors work harder. Did it ever get wet or crashed? How about did you ever forget to take of the gimbal guard ? I really do not know as I have never heard that or seen it reported before.
I dont crash or get wet, or anything i just turn on today to fly and get this issue
Cuando guardas el Evo, lo guardas en algun envase que mantenga la humedad? Tiene algun signo de corrosion?
When you put away your Evp. Do you put it a way in a place that keeps the moisture? Does it show signs of corrosion?
El evo lo guardo en una repisa de ropero
How about sand? Like beach sand. Any way it might have got some dirt in there?
That’s what a local guy from Dji tell me he’s going to check the autel tomorrow the last time I fly I do it in a beach like a month ago, but I don’t turn on or off on the sand
Sand particles are in the air. You might not see them, but they acumulate between the cracks and crannies. Try using a can of air and see if it helps any.
Skygod34
