Firmware update via Smart Controller and GPS issue. - SOLVED
I recently purchased the Smart Controller V2 for my EVO II Pro V2
Start up and pairing was OK. I was connected to the internet and went to set up some missions but the Map functionality is broken. None of the three modes (normal, hybrid, satellite) show anything. Even when I set the "Home Point" in the settings, it says "Cannot change when the aircraft is landing or not armed" or similar.
I noticed an update to the App in the settings and did so
App updated to v1.0.65 - No problems, but the Maps/GPS still not working.
Immediately a Firmware Update was available for the UAV v2.1.77. OTA updating continually fails. I cannot find the file to perform a manual upgrade from the drone.
Here is the current Firmware versions (relevant ones I think)
Flight Control v0.0.4.58
Camera: v0.2.32.66
Remote Control: v3.1.0.10
Image Transmission: v2.0.1.4
Batter v0.0.15
At the moment, I can fly it with the standard remote and I would like to continue to do this as a fall back (I have been able how to pair and unpair both the standard and smart controllers)
Any help would be greatly appreciated.
----EDIT: SOLVED
Thanks to Dave, I successfully applied the 2.1.77 Firmware.
Steps:
1) Format SD Card
2) Extract Firmware Zip to root of SD Card
3) Power on Smart Controller
4) Insert SD Card in aircraft and turn on
5) Wait....Took 15 minutes
6) Turn Off Aircraft and Smart Controller when told
7) Power on Smart Controller
8) Power on Aircraft
GPS signal is excellent, maps are good now. Created and ran two missions without issue. Everything is working correctly except for setting the Home Point in the settings. Still complains about landing or not being armed.
Doing this by the letter, and still it hangs at 100%. SO tired of this.
Autel-euducational
