Evo Max 4T. How to manually choose 2.4ghz channel.
Solidhouse
Hello everyone, I’m trying to set my Evo Max 4T to use 2.4ghz only. I do not see any settings to change the transmission frequency. Has anyone else noticed this? Perhaps Autel will fix this in a future firmware update.
..one of the many missing features :-(
Your issue is addressed in the new firmware update as of 8/23/2023. Press the "More" menu button, then "Settings", then "Transmission" and select your "Transmission Freq. Band"
I’m happy that they are addressing this with a firmware update.
One thing that I’ve noticed after the firmware update. It does allow you to choose the frequency. However, it does not allow you to manually pick a channel.
Thank you for the notice. I guess we need to use a meter to verify a definite change.
dbuckner0138
