Custom painted evo pro 2
Status
Not open for further replies.
wizard08
This is a first look at my custom painted pro 2. I still have to clear coat it and put all the screens back on, but it should be in the sky early next week. I'll post more when it's done
Will not it be harder to see not that it's white?
Maybe, but does it matter? It's flown through the camera, not by visual sight
  • Wow
Reactions: Lepi
Not true if you're flying legally. There is not a country in the world that I know of that does not require a visual line of sight!
Reactions: Lepi
So are you saying if I can't physically see my drone, then it's not being flown legally? I normally can't see my drone once it's 50 ft away. If it's for other people, it has a metallic silver bottom and trim.
  • Sad
Reactions: Lepi
That is correct! If you are unable to physically see your drone you are flying illegally. 14 CFR § 107.31 - Visual line of sight aircraft operation. It doesn't matter if you are flying recreationally or Part 107
Reactions: Lepi
i would have to guess most people fly their drones illegally
Your guess would be incorrect. I suppose you would guess that everyone speeds on the interstate as well.
Reactions: Lepi
how would you survey an acre or more of land if you have to always have a line of sight to the drone?
I use qualified visual observers and move around to keep VLOS
Reactions: Lepi
Status
Silentor
