EVO Lite + Camera
dinesh75
Hello all, Long time user of EVO II pro V1 drone here. Been quite happy with the drone, except that it's a bit heavy. Given that I want to do more air travel, I decided to buy the lite plus because the camera seems the same (or very similar).
In the EVO II pro, I used to do custom panoramas as follows:
a) Pick the custom camera settings. ISO, F stop, and the base shutter speed
b) Take 5 AEB images (via changes in the shutter speed).
c) Move the drone/camera in the desired direction, repeat
Finally, bring all the images into Lightroom, and do the HDR processing, and the panorama stitching. I have been quite happy with the results.
However, I find that I am not able to do something similar in the Lite plus. If I pick custom Camera settings, it seems to go into the "Pro" mode, and then AEB is not available. What are the options? Of course, I can manually do the AEB by changing the shutter speed, but it's a pain, especially when the light is changing fast (I mostly shoot at dawn/dusk, so the light changes rapidly)
I see that it has a panorama mode. Is it possible to have AEB for each of those panorama shots that the drone takes? Additionally, is it possible to have the individual files that make up the panorama?
Has anyone been able to do what I have in mind? Suggestions Welcome!
You have a lot less options in this stupid app called Sky.
Explorer at least was with more options, even if was with many bugs.
Also sensor in Lite+ is not even close to E2P V1, is a junk comparing both.
Sorry
Cgmaster1
