I have not been able to yet... I did upload thermal RGB data and got a non-radiometric ortho. but did not save or get screenshots.
I'm not familiar with the software but I am getting DTMs not orthos yet.
Its seems the software is more suited to DTMs and DSMs
I have had no problems generating accurate DSM/DTMs or orthos using GCPs.
i cant even get the GCPs to load up in sim active
settings
Reactions: yarrr
iam going to upload a project that has 6 points on it with the RTK EVO, can you process it in SIM?
1200 to 1300 photos as long as google drive loads it correctly and dont miss files
It turned out beautiful in DD a while back, I can not get the GCPs to upload in simactive, looks as if they don't use CSV files. I converted it to a text file and it shows up but won't upload
I can not get an ortho, just a DTM
LOOK at this makes no sense, Z compared to X and Y
what file type for said GCPs, I tried CSV and Text, but will not upload?
you get the screenshots for rs2, hope that helps, but I'm pretty sure you were money all along
Can you help me with this? or process it?
I will check to see if there is similar functionality in Correlator3D.
When you do the aerial triangulation you can set the Bundle Adjustment EO to RTK/PPK Assisted. We don't use GCP's with RTK but if you do you can use them as your ground reference.
Reactions: jmason702
Yes, you can add GCPs in a couple of different places and select GCPs as your Ground Reference. See attached screen captures.
1#DroneLife
