EVO II Dual 640T V3 Enterprise with RTK Question
I have an EVO II Dual 640T Enterprise with the RTK Module mounted on the top. I have several questions.
I'm getting an RTK not ready error on the main screen and the drone won't take off.. I thought that I could disable remote connection on the drone and in conjunction with an NTRIP connected base I could do PPK by merging, with software, the NTRIP data from the base with the data files generated by the RTK module when recording video. What am I doing wrong?
As you can see from the attached pictures the RTK module has acquired 19 satellites and the internal GNSS has acquired 18 satellites with a strong signal.
One image shows the red RTK is not ready indication from the main screen.
One image shows the Current Warning Message screen.
One image shows the RTK configuration screen where RTK connection options is set to None.
Dronesanddogs
