Update evo max 4t
slavikklichko
good day
please help
we use evo max 4t for reconnaissance of the armed forces of Ukraine.
during the shelling, the control panel was lost. bought another. how to flash a drone (or a remote control), because they do not connect to each other? which firmware is on the plane is unknown. what program can do this? maybe there are firmware files or where to get them? instruction?. The Armed Forces will be grateful
put a battery in the drone. power it on. Then double press the battery button (two quick presses in succession) The battery lights should begin flashing. While they are flashing it is in pairing mode.
In the controller there is a menu item called information sharing. the first option "single link" is for linking a single controller to an aircraft. The second link is for the AI mesh connection, unless you are using multiple controllers or aircraft together, stay away.
Reactions: Takashira
good day
please help
The firmware that you use on the aircraft calls for a specific firmware to be loaded on the transmitter and no other. See the following: EVO Max Series Related Downloads - English Version
rtillman
