Unsupervised Battery Charging and Safe Transport
DroneDriver
Northern DE
I don't know about you, but charging Lipos, even if they are smart batteries, makes me nervous to leave the house even for a moment to check my mailbox. Solution: Ammo Box
After cutting a notch in the box for the charging cord and placing a little electrical tape there - it works pretty good. I hooked up a battery, closed the lid, and plugged in the charger. Surrounding air temperature outside the box was was 78°F (26°C) in the room and I never heard the little fan go on inside the box (not mentioning the brick squeal :mad:). Life is good!
I'll probably add some sheet rock siding inside with compartments next. This way I can transport my batteries safely in the car and not worry about them going Fukushima on me.
Cheers
Reactions: brian bwin
Been meaning to do the same thing, but I only have one ammo box...and I kinda need it for my ammo. :) Just been too cheap to buy another, but in hind sight I'm sure I'd say that spending $15 for another can would have been cheaper than replacing my house!
There's also this option...pretty cool if you have the extra cash!
I know what you mean. I used a coupon at Harbor Freight and got one for nearly $12, but then discovered that I had an old toolbox lying around that I could have used instead of spending money. Check this out:
chuckster58
