Planning Vertical Mission
RLH
Has anyone found a good way to fly vertical mission using Evo 2 Pro V3 and smart controller?
What do you mean by vertical mission? All vertical images are is a landscape image that has been cropped to a vertical aspect ratio unless you physically turn the camera sideways which is not possible with the EVO. So just fly a regular mission, capture the images, then in your post processing software apply a vertical aspect ratio template to all of the images. I use this technique all the time to make IG, FB, and YT versions of the same video or images.
When referring to a vertical mission, do you mean a facade (Dronelink) or vertical scan (UgCS) mission? These are typically used for vertical inspections of buildings or other structures.
Example,
TRY HERE: Problem Feedback-Autel Robotics Enterprise Drone, Quadcopter & UAV for Sale | Leader in Drones
cambero21
