magnetic interference and gimbal does not calibrate evo 1
Piratas16
Gentlemen, I have an Autel Evo 1, I only changed the roll flexible and when I turn it on, the gimbal goes crazy and does not calibrate, the same drone sends a magnetic interfenece message, someone has solved this problem without sending it to Autel Robotic and they will send it to you. new one.
What are you saying? How do you fix this issue with the gimbal going crazy?
abthegrey I apologize for answering you until now, and if only I changed the flexibel of the gimbal roll and it goes crazy and apart from that it sends a magnetic interference message. You will know how to solve it.
Aerugo
