gimble cover to tight
The camera has to line up square with the sides of the cover or it won't go on correct... I dont know why the shut down default is 30 deg down and tilted sideways.. Annoying
Reactions: kelly1
Thank you. I am afraid the cover is going to damage the camera. The cover is supposed to protect it.
Also occasionally the back motor does not shut off at the same moment as the other three motors. Causing the drone to slightly spin. That’s the only issues I am having. Thank you for your help.
Gimbal cover issue solved. Works as it should. Takes some tinkering with to get it in place.
Marwan
