Frame Rates??
Flytechguy
If anyone is confused on frame rates and need a quick guide here you go! I use my Evo all them time and being able to use 60 fps is amazing but is it always the right one to use? LEt me know which frame rates you guys use on your videos?
I typically used 60FPS then in post-prod, slow it down to 30 and also double the shutter speed or depending on light may go higher.
Interesting do you use nd filters as well? And I assume you mean double the frame rate to get the correct shutter speed following that 180 rule?
Ktighe
