Fly problems, but all wings are spinning
lorirenee23
I hit a board and broke a wing I replaced it now it won't fly up when I go up it goes towards the left side all my wings are spinning
It would help if you told us what model you have. I would imagine that you have 2 styles of props so if you are running 3 of one and just 1 of the other that might effect your flight.
Be sure you have the propellers on the correct motor. There is one set of CW and one set of CCW and they are criss-cross to each other:
A B
B A
Hope this helps.
Even if I replaced one wing , when I press up for it can go up it drags itself to the left
if you used the wrong propeller it might or if the arm is not opening up correctly.
can you post a picture from the top with all 4 arms extended, that might show something plus we could see all 4 propellers at the same time.
Reactions: CactusJackSlade
Sounds like you will need to contact Autel Support, below is their contact information.
"If you encounter problems when using the aircraft devices, you can contact our customer service via below email channels and provide information below:
1) Serial number of the aircraft.
2) Photo or video of the problem or any warning message.
North America :​
Email : [email protected]
Europe :​
drnd
