EVO remote control antenna hinge pins coming out?
I have less than 2 hours on my Evo and friday i had some free time and pulled out the RC from my case and one of the antenna fell apart at the swivel....so I sent an email to Autel warranty with pictures attached hoping they will cover this under the warranty policy.....fingers crossed
Here are some pix of the toothpick inserted and roughly trimmed, the spot of glue on the other pins that are still there, and the toothpick type I used. You have to be a little cautious inserting the toothpick ( or whatever is used) since it has to go under the antenna wire to make sure there is freedom of movement for the wire when folding the arm. And like I mentioned, the wood can be touched up with a black marker if needed?
Did you make a hole to insert the tootpic?
BadDog
