EVO 2 Pro stops midflight?
alex_markov
Today I had a very strange experience I had a long flight over a dam and on the way back switched to Ludacris mode 72 km/h when EVO 2 suddenly stopped while the stick is fully pressed then start moving very slowly then stopped again... and this happened several times - on the screen, there was no message but before that I had upward sensor have obstacle with nothing on diagram???
Something else in the area there was a small airplane (I was closer to the ground he was some hundred meters above) can it be my EVO was sensing it and reacted oddly - as on the second flight in a different place there was nothing like this???
here is speeded up footage of stops
I have had this happen on numerous occasions. Normal speeds no matter the flight mode and all of a sudden...4.6mph max even with every sensor disabled. I have the same conclusion too. It is sensing objects even while disabled. I have contacted Autel and sent screen recordings of it occurring. They provided no amswers to the issue other than calibration of the sensors. Calibration shows every sensor is fine. Calibrated them to be sure and it still happens with them on or off. So frustrating!
Reactions: alex_markov
Coming from DJI EVO 2 feals rough on the edges but I'll give them a chance ;)
  • Wow
Considering how many videos you have flown in the mountains without issue on the DJI , im thinking this was the GPS disconnect , and reconnect
This would explain the Stop and hover.
dbuckner0138
