Positioning with NTRIP caster does not grab fix
zico1993
Hello friends, I have a GNS receiver with the mosaic x5 septentrio module, I have used it as a base to emit differential corrections via NTRIP, the rovers of the same brand receive differential corrections with fix positioning, however the Autel Evo II pro RTK V3 Drone achieves connect to the NTRIP server but receive differential corrections with single positioning.
What RTCM messages should I add to the receiver and at what correction update rate so that the Drone can correctly interpret the correction through the local NTRIP caster?
drnd
