Lithium Polymer Battery Care
if you charge your lipo's at a higher rate they wont last very long, the autel charging hub can charge 4 autel lipo's at the same time, i just dont understand why you want to use an aftermarket charger????
My goal is to have access to a set of charge cables that can be adapted to obtain Internal Resistance measurement of my batteries... to extend their useful life. Autel's goal is to sell me as many batteries as they can.
You mention Autel's quad hub... can that piece of equipment use any kind of cable adapter, since it only uses the single OEM charge cable to connect the quad tower? Not without modifying it in a manner that surely will result in an invalidation of any warranty.
If you do not understand the reasons behind monitoring IR levels, I suggest going back to the hyperlink in my original post in this thread... particularly the sections on Discharging and Storage.
Reactions: Azelgato
ok.
Ktighe
