GSD Calculator
Crusader
This is the GSD Calculator I got from one of the Pix4D resellers with a few of my own conversion calculations. The imperial calculations are mine and the metric are theirs. It's set up for the Evo. If using another drone, you'll need to input your camera specs. (Everything in the "Calculator" box i.e. Focal length, sensor width, etc...). After you're set there, you can switch back to imperial measurement for ALT if you fly in feet, and enter it in the yellow box. The spreadsheet will take care of the rest.GSD Calculator modified
-Crusader
Cgmaster1
