Does anyone have Firmware V1.9.10 For Nano Plus to be able to update manually
Aureliohdez
hello everyone
I need to update manually someone has the firmware
V1.9.10
for android and can you leave a link to download please
I think it is the only solution I have since my drone says it is disconnected, it has the firmware EVO-Nano_FW_V1.8.5 but it always says Aircraft Disconnected
First, consider that some people have more problems after the update. BEST WISHES...let us know how things work out please.
FROM [email protected] on 12/8/24:
Please download the lastest firmware for your Nano+, also do not forget to upgrade Autel Sky app in App Store:
EVO-Nano_FW_V1.9.10.zip
Here is guidance on how to update firmware:
1. Before update, make sure the drone's battery level is at least 25%.
2. Format the SD card (FAT32 format), and copy only the firmware file to the card.
3. Power on the drone and wait for 2 minutes. Then install the SD card into the slot.
4. The indicators on the arms are flashing, indicating that the update/rollback has started.
5. Wait until the indicators are steady on, the update/rollback is complete.(Usually less than 15 mins)
6. Wait for 2 minutes and reboot the drone.
7. Pair up and check whether the update/rollback is successful or not.
*Note: It is important to note that once the firmware package is successfully read (the aircraft will start flashing after inserting the card, and the flashing will stop after a period of time), the firmware package in the SD card will be automatically deleted if the firmware is successfully flashed.
Guidance Video:
https:/app.autelrobotics.cn/statics/cdn/tutorial%20videos/%E8%8B%B1%E6%96%87/SD%E5%8D%A1%E5%8D%87%E9%99%8D%E7%BA%A7/How%20To%20UpdateRoll%20Back%20Firmware%20With%20SD%20Card.mp4
If you have any further questions, feel free to reply directly to this email and I'd be happy to assist.
Best Regards,
Chris Xiao| After-sales Technical Support
hello everyone
V1.9.10
are you using Apple or Android device? Do you have the ability to switch ? I generally think the Apple Sky app is the better way to go. Primarily because allows using something like the iPad Mini which gives a much better RC experience. My phone is Android, but I would use that only as a backup.
Hi All,
I updated as per the instructions above and now I have my drone back fully functional (subject to test flight!)
I have the nano+ and update lights were as follows. My autel app was the latest available as at Jan 20, 2025.
1. Powered Drone on for 2 minutes - green light slow flashing
1a. I also powered on the controller.
2. Inserted sd card with unzipped folder only on it. (EVO-Nano_FW_V1)
3. Tail light flashed orange two or three times
3a Controller beeped and lights left and right flashed for about 5 minutes.
4. Tail light flashed green for about 10 minutes
4a Controller beeped and went back to normal state of charge lights.
5. Tail light solid green after the 10 minutes.
6. I left for another 5 minutes and then turned off drone
7. Turned drone back on and all information in the About menu shows drone updated to latest firmware 1.9.10
I was nervous doing this as I didn't particularly want a Drone paper weight!
All worked well though, so go for it!
Did it launch? I was not able to launch on iOS so switched to android....and have 7 launches out of 121 attempts...and still have frequent seemingly random disconnects. So I'm trying to figure out if it is a software or hardware (or operator) problem.
Sounds like your having real issues if only 7 out of 121 attempts to launch!!
I have had one out of one successful launches since the update to V1.9.10.
The only problem I had was one crash of the app on iOS. I still seemed to have control without the app open.
I have changed the setting to hover for disconnects rather than return to home.
Hi, I bought a new phone, installed the updated
version of Sky app, tried with different SD cards and phones but OTA update kept failing. I tried this method, but as I instert the SD in the drone, the light becomes flashing red instantly. So i uninstalled the sky app and got the previous 1.4.68 version as the update prompt was annoying
hello everyone
V1.9.10
Look in the Evo Nano thread.
rtillman
